Emrah AKAY Posted November 16, 2018 Report Share Posted November 16, 2018 Hi Support, I am Emrah at TESAN from Istanbul, I wrote a program with UniStream and insert a memory card. But there is a problem; PLC is saving random data sampling. for example I saw the trend history, it keep in memory different time or didn't keep in memory sometimes. before it saved three hours and later didn't save two days. an other time when I saw it saved five hours but didn't save three days. I used trend start bit with 'General ON'. But it can't keep in memory every time. What is your solution? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Guy Sela Posted January 7, 2019 Report Share Posted January 7, 2019 The Sample file should be saved in the folder name you set, in my case "MySample". A file will be saved to the SD once the sample count will reach 60,000 samples or if you will stop sampling using the "Start/End Sampling". "Start/End Sampling" can be set to power up value `1`. You can check the next video on Data Sampling Quote Link to comment Share on other sites More sharing options...
