FredrikH Posted November 22, 2018 Report Share Posted November 22, 2018 Normaly I use "SD card manager" and "Import SD folder" to convert utr files to excel. This works for smaller files but with larger files it aborts the conversion and I get error message "Exception of type ´System.OutOfMemoryException´ was thrown" How can I convert the larger files? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 22, 2018 MVP 2023 Report Share Posted November 22, 2018 Not sure this is the answer, but was the suite installed as right click Run as Admin, and then the various program .exes set to run as admin as well? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 22, 2018 Report Share Posted November 22, 2018 Hi, we are familiar with this issue. The created excel file requires a lot of ram for this amount or rows (near 1,000,000 rows). The SD Card Suite is compiled as 32 Bit, so it is limited to 2 GB of ram for the process (but actually, due to fragmentation, the error will happen around 1.2 GB). Compiling the SD Card Suite as 64 bit is not possible since the Chart control is compiled as 32 bit (probably because it uses OpenGL). We are checking few solutions, but I can't promise anything, and it will take time to check them and implement them. Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 25, 2018 Report Share Posted November 25, 2018 @FredrikH, Please download and install the attached version. It uses a different 3rd party DLL that creates excel files, and it reduces the total used ram to a safe level, so you should be able to convert your files using SD Card Manager. Please update me if it helped. Thanks. Unitronics SD Card Suite 2.0.66.zip 1 Quote Link to comment Share on other sites More sharing options...
FredrikH Posted November 26, 2018 Author Report Share Posted November 26, 2018 Thank you Saragani! With the attached version I could convert the files and recover the data! Quote Link to comment Share on other sites More sharing options...
