MVP 2023 Ausman Posted November 26, 2018 MVP 2023 Report Share Posted November 26, 2018 Responded to a private message about what the J terminology is, that appears in product naming. It is simply the fitting of the flat fascia. So in case you don't know, a V130-J-RA22 is the equivalent of a V130-33-RA22. The same naming system is across all the models. In Visilogic choose accordingly. Cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
