'Gennady Kozyukin Posted November 28, 2018 Report Share Posted November 28, 2018 Hello, In our lab we have xyz table for diode laser with v570 controller. After the battery go dead I updated v570 to the newest firmware and downloaded the system file. Everything is ok but the X and Y axis position status show negative values while I jogging in positive direction (after homming). How could I fix it? I have attached the vlp file. Thank you. Laser Technion X Screw.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted November 28, 2018 MVP 2023 Report Share Posted November 28, 2018 Maybe min and max position in system parameters is wrong. Max is in min parameter and min is in max. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 28, 2018 MVP 2023 Report Share Posted November 28, 2018 This topic is doubled. I moved the other one Gennady did as guest in the lounge into this area of the forum, without realising it had been posted here as well. The other one has the .vlp. and everyone please only work from that one. I wish people would not do this, it just confuses things. The other one is here: cheers, Aus Quote Link to comment Share on other sites More sharing options...
