Long Press Button Implementation (counter reset)
  • MVP 2023
OK.  Let's break this down to the separate things needed to achieve this.
1).  Push a button.
2).  Count a period of time that the button is pushed for.
3).  At the end of that period of time turn on an output.
4).  The output does the required action and then resets.  It might even show something on a screen that says it has happened ok and you can now stop pressing the button.
Hmmmm.  Well that would either be a timer, or a count incrementing in value, continuing to do so whilst the button is held on, and then resetting ready to do it all again on next long push.
It's over to you now to work on this idea.
cheers, Aus
  • 4 weeks later...
It’s not “pre coded”. Fairly simple to construct however. Link display element ( touch feild) to a memory bit (MB1), in ladder use NO contact to drive timer coil, second net: use a PTC (positive transistional contact) to drive a reset integer function —[R]—
     MB1                             T1
       T1                                C1  (or T)
—-|P|————————[R]——
alternatively I believe timer can "self one shot" but would repeat cyclically if button was held longer than usual:
     MB1         T1            T1
       T1                                C1  (or T)
—--| |————————[R]——
