JotaPey Posted December 13, 2018 Report Share Posted December 13, 2018 I have a DTI in which I want to search a column for a string with a specific prefix. The column contains strings of 25 characters each with a unique 3 letter prefix. How can I perform a search returning a match for a given prefix? In other words, I want to return the string with prefix "ABC". Thanks in advance! Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted December 13, 2018 Report Share Posted December 13, 2018 Hi JotaPey, have you tried the Find Substring function block?....field A the string where you want navigate; field B the substring to search; field C the starting point to search in the main string; field D the result....for this last a positive result means that the substring was found....negative result means that the primary string doesn't contain the secondary string...you can navigate in your DTI until find what you want. Quote Link to comment Share on other sites More sharing options...
