  • External Moderators
I've got an idea for pop-up screens that will look really neat, but whenever I try to copy a screen from Visilogic (ctrl-alt-print screen) to use as a background image on another screen, it gets the scaling wrong.
Two ideas:
1. How hard would it be to have a menu option in visilogic to export an HMI to an image file?
2. For a gold star, how hard to assign one screen to be the background image of another?
Mind you, the background screen is nothing - just an image, no functionality.
Thanks,
TM
Hi TM:
Here's how you can get the display as a background image:
-Open Remote Access (click the eye glasses and select Remote Access from the menu).
-Locate the display you want to make an image and press Alt+Print Screen.
-Paste the display in a paint program.
-Resize the image to your PLCs resolution. (for a V350 this is 320 x 240).
-Save image as a 256-color bmp.
-Create a new HMI display and add an image.
-fit the image to the size of the display.
-select the image file you created.
The display now has a background image with no functionality that you may place a pop-up window over top of.
Hopefully this helps.
Jared
