Tech Posted December 29, 2018 Report Share Posted December 29, 2018 Dear sir, How to hand shake v700 to v700 pls provide solution.It is possible to handshaking v700 to v700. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 29, 2018 MVP 2023 Report Share Posted December 29, 2018 You'll need to be much more specific. Which communication protocol are you trying to use and what exactly do you mean by "handshaking"? Quote Link to comment Share on other sites More sharing options...
Tech Posted December 30, 2018 Author Report Share Posted December 30, 2018 Dear sir, Actually case is we have 4 plc for 4 individual vessels A,B,C,D,So we need to transfered product to A vessel to D.That 4 Plc having 4 individual Festo valve (16 way-Tcp/ip).So how to transfer product? Pls suggest Quote Link to comment Share on other sites More sharing options...
Isakovic Posted December 30, 2018 Report Share Posted December 30, 2018 There is a "TCP connect" functon if you were referring to making ethernet connection. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 30, 2018 MVP 2023 Report Share Posted December 30, 2018 It sounds like you are using MODBUS TCP. There are several example programs that came with your VisiLogic installation that show how to set that up on a V700. Take a look at those and see if they are of any help. 1 Quote Link to comment Share on other sites More sharing options...
