marcelo_chaura Posted January 7, 2019 Report Share Posted January 7, 2019 Hola, quiero consultar si el software de Unilogic reconoce los sistemas IO LINK de SICK , ya que todos los vídeos que he visto lo trabajan mediante el software de rs logix 5000 . Alguien ha podido realizar la comunicación ethernet entre un SICK IOLG2EI y PLC+HMI 15,6" USC-P-B10 , por favor indiciar que pasos debo seguir ya que no manejo el software UNILOGIC. gracias Quote Link to comment Share on other sites More sharing options...
Ofir Posted April 16, 2019 Report Share Posted April 16, 2019 Hi, There is no direct support for IO-Link in UniStream but we know about customers that implemented Ethernet/IP communication with the IO link HUB and UniStream PLC. Check with the IO link supplier whether its HUB supports Ethernet/IP. Quote Link to comment Share on other sites More sharing options...
