NutzlosNorm Posted January 25, 2019 Report Share Posted January 25, 2019 I have a USP-104-B10 with the "Barcode Scanner_test" sample program loaded. I have an IDAutomation SC7USB 2D barcode scanner attached to a panel USB port. I can scan barcodes that only include digits without a problem. When alpha characters are involved, strange things start to happen. For example, this barcode "V30AE000041" is read as "v#0aE)00041", "A - Code 39" becomes "a - cODE 39" and "C - Code 93" becomes "c - cOde 93". I connected the scanner to my PC and was able to scan these barcodes correctly into a Word document. Quote Link to comment Share on other sites More sharing options...
NahumS Posted April 16, 2019 Report Share Posted April 16, 2019 Hello Nutzlos Norm, Please perform the following procedure for a better & faster debugging: 1. Extract HDRecorder.rar ( Attached) 2. Run "Keyboard.exe". 3. Scan using the barcode: 4. Send the created log from "C:\Users\SOME_USER_NAME\Documents\Unitronics\ScannerReaderLogs". Example: Please send me back the log file. HDRecorder.rar Quote Link to comment Share on other sites More sharing options...
GiaDatric Posted February 9, 2023 Report Share Posted February 9, 2023 It's a complicated issue since erroneous barcode scanning can be painful. But I have a potential solution for you! Have you tried using optical character recognition? It's a handy tool to avoid those weird scanning mishaps. I've been using the SmartEngines scanner at smartengines.com/ for a while now and am very happy. Since they offer automatic and eco-friendly document scanning with their advanced OCR technology. It is worth a try, especially since you can adequately scan barcodes on your PC. Fingers crossed that this might be the answer you're looking for! Quote Link to comment Share on other sites More sharing options...
