I moved this to the proper forum.
An EDS file is used for CANOpen communications.  Look at the Help on this and let us know more specifically what you need.
I tried opening the UniversalRobot.eds file with the UniEDS tool and there's nothing in it.
Ah.  That's the link to the Ethernet/IP description, which is typically used with an Allen Bradley PLC.  If you want to go with Unitronics I'd recommend the Modbus TCP connection:
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/modbus-server-16377/
You can set the PLC up as a Modbus master (client).  Let us know what you're trying to get the robot to do and we can help with communication.
Hello
Joe
I just want to communicate v700 with three universal robot.
In plc i want to read all parameters of all three  universal robot. Like joint temp, tcp value,angle,co-ordinate.
Is it possible ?
If possible please let me know the settings in plc v700
