Alan Edwards Posted February 7, 2019 Report Share Posted February 7, 2019 Hi I have a program on a V700 that is doing some data logging and FTP ing the data log to an external PC. I have to add '.CSV' to a string to create a file name. I am using the Ins. to Str. FB. On the function block variable A (MI1670) contains the original string, variable B (MI1600) used to contain the code for '.CSV' but these numbers have been lost, variable C is set to #8 and variable D (MI1610) contains the final filename. What numbers should go into MI1600 and MI1601 to give me .CSV at the end of the file name. Any help gratefully received. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 7, 2019 MVP 2023 Report Share Posted February 7, 2019 Quote Link to comment Share on other sites More sharing options...
Alan Edwards Posted February 7, 2019 Author Report Share Posted February 7, 2019 Many Thanks Flex727 Quote Link to comment Share on other sites More sharing options...
