Guest BobH Posted February 12, 2019 Report Share Posted February 12, 2019 Hello, I am a student , also in PLC programming. After I got used to Unilogics I got a internship order. I need some help with TCP data Rx/Tx, especially with the programming ladder blocks. My program is now so far working that I can see that my PLC and Hercules ( on laptop ) are connected but then i can't get it working. First up i want to try to make a very simple light lit up when i received data. So I had it configured like in the image. The day before I programmed it like that I was able to see the quantity of byte's that was received in box D. But today with de configuring in the image that isn't even working. Questions i especially have : - The block does need to know when (at how much byte's) the box E (remote IP) it must power up, right? - I really want to know what the functions are from the I/O's of the TCP SERVER Rx/Tx data block? Can someone please explain it in more simple language? thanks for help in advance Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 12, 2019 MVP 2023 Report Share Posted February 12, 2019 Moved to the correct forum. Quote Link to comment Share on other sites More sharing options...
