Hi Dears,
I can identify a lot of benefits including OPC UA server capabilities directly at CPU level. This could standardize OPC communications for OEM vendors and leveraging data collections in upper data layers.
Do you have plans to integrate that functionality ?
Congratulations including MQTT protocol, this is also a very good progress!!! I tried in the pass define an standard XML (web methods module) to communicate, but this is definitely much better.
Regards.
Marcos.
