Interroga Posted February 23, 2019 Report Share Posted February 23, 2019 i am create application with messages for audit traill actions the operation. I wold like select the message with index , show in left collun. But not found way for select message for write in table dti or external ( sql table). I need help for optimize application and not repeat many times same code. i hope developer team create one way for create selection more easy. regards, Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted March 22, 2019 Report Share Posted March 22, 2019 Sounds like you could create a UDFB to 1. "Find DTI Column Value" 2. Insert row data into a holding struct 3. "Write Row to DTI" Your Function IN could be a variable with the data type you are searching for in step 1 above. This would save you lots of code if you need this multiple times. Quote Link to comment Share on other sites More sharing options...
