Gadun Posted March 6, 2019 Report Share Posted March 6, 2019 Hi guys. Well I live in Brazil and I do not speak English, in case I'm using google to translate, I ask for your understanding. I'm using the CLP vision SM70-J-R20. I'm using an encoder of 800ppr, and the speed of the Z axis shift is 65.5 rpm. The machine works with two different measures of the same encoder, the first indicates the general positioning that can not be erased, the second reference that is in the manual can be changed and erased by the user, in case the user enters a measurement in the manual the machine should only move the measure you entered. thanks for the help Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 7, 2019 MVP 2023 Report Share Posted March 7, 2019 Can you post your program so we can see the rest of the details? Joe T. Quote Link to comment Share on other sites More sharing options...
Gadun Posted March 27, 2019 Author Report Share Posted March 27, 2019 Good evening, sorry for not replying before, my computer was broken and was in maintenance. Joe T what I would like to use and something like this program I did, but the maximum I got was that, I know there is a more practical and more accurate way. Encoder com 3 Posicionamentos.vlp Em 07/03/2019 às 02:22, Joe Tauser disse: Você pode postar seu programa para ver o resto dos detalhes? Joe T. Quote Link to comment Share on other sites More sharing options...
Gadun Posted March 27, 2019 Author Report Share Posted March 27, 2019 this is the final project that I intend to use but I am locked with the head coming out smoke kkkkk, until I read some posts to the reapeito but I did not understand. price very much to your aid. Lagonegro Serra Ponte 04.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 28, 2019 MVP 2023 Report Share Posted March 28, 2019 First, you're doing all your encoder scaling with floating point. I would recommend doing everything in integers with a virtual decimal - for example 1000 = 10.00. The Vision series can be difficult to use with floats. Can you share the actual scaling you're trying to get ( x pulses = y meters)? The other program you posted simply compares the encoder value to a bunch of numbers and sets coils when the encoder is in a certain range. Is this what you're trying to achieve in the end? Joe T. Quote Link to comment Share on other sites More sharing options...
Gadun Posted March 29, 2019 Author Report Share Posted March 29, 2019 23 hours ago, Joe Tauser said: First, you're doing all your encoder scaling with floating point. I would recommend doing everything in integers with a virtual decimal - for example 1000 = 10.00. The Vision series can be difficult to use with floats. Can you share the actual scaling you're trying to get ( x pulses = y meters)? The other program you posted simply compares the encoder value to a bunch of numbers and sets coils when the encoder is in a certain range. Is this what you're trying to achieve in the end? Joe T. Yes (x pulses = y measure) ... the program is being developed for a marble cutting machine, the operator enters a desired measurement and the machine executes the positioning. I already have a part of the program ready, which I did two years ago in vision120-22, I'm stuck because I would like to use 2 measurement references of the same axis, one of positioning the machine and another where the operator types the measurement, the problem is when I turn off MI0 I can not keep another recorder. The second question you asked is what I'm trying to get but it did not work, it's not necessary, I'd like to try something similar. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 29, 2019 MVP 2023 Report Share Posted March 29, 2019 Can you just copy the HSC value to two different MLs and operate on them independently? If you need to reset the operator's value you store the current value of the "master" HSC position and continually subtract it as an offset. Joe T. Quote Link to comment Share on other sites More sharing options...
Gadun Posted March 29, 2019 Author Report Share Posted March 29, 2019 39 minutes ago, Joe Tauser said: Can you just copy the HSC value to two different MLs and operate on them independently? If you need to reset the operator's value you store the current value of the "master" HSC position and continually subtract it as an offset. Joe I already tried copying from ML0 to ML1, the problem and that when I delete the ML0, the ML1 also goes out, and when I try to delete the ML1 I can not. I read something about it in a post but I did not understand the logic that was explained.. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 29, 2019 MVP 2023 Report Share Posted March 29, 2019 I'm talking about something like this- Whenever the machine reaches the position want the operator to start from you trigger MB 0 to create a reference. The SUB block ties them together and ML 2 will equal 0. Then you compare the value of ML2 to something to get your operator cut. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
Gadun Posted March 29, 2019 Author Report Share Posted March 29, 2019 Master Joe Tauser ... I just have to thank you for your patience and especially for your help, it was what I needed, as I burned my head with it's was so simple 😅 thank you. Quote Link to comment Share on other sites More sharing options...
