YINGD Posted March 11, 2019 Report Share Posted March 11, 2019 I need to find an intrinsically safe rated mouse with a USB connection for an Explosion Proof Environment. Does anyone have any experience finding one that works? I have used a standard USB Mouse without issue but I have found that when I purchased the mouse fund at the link below, it works on a PC but not with the Unistream Panel, instead, the HMI would not detect it. I am thinking that it has something to do with either the driver or that it is intrinsically safe and perhaps the signal is a bit too weak. Rather than buying multiple mice until I find one that works, I was hoping that someone can point me in the right direction. https://www.spartonre.com/ruggedkeyboards/rugged-pointingdevices/ftm-pm-fsr-panelmount-industrial-pointing-device/ If it is a driver issue, does anyone know if there is a definition of the driver in the Unistream panel that the mouse needs to have that I can then ask the mouse manufacturer if it has? Any feedback would be appreciated. Quote Link to comment Share on other sites More sharing options...
YINGD Posted March 11, 2019 Author Report Share Posted March 11, 2019 I did ask Stealth about the diver required and he had said " There are no special drivers required for the StealthMOUSE and it just needs 5 volts at 50ma from the mouse port. That being said the StealthMOUSE is only validated for PC use so it could be a compatibility issue with the Unistream controller" I suppose the question now is what the Unistream controller needs to see in a compatible mouse and whether there are additional mouse drivers available for the Unistream Panel. I should mention that as shown in the attached picture, I am running the latest version of Unilogic and my firmware is up to date. Quote Link to comment Share on other sites More sharing options...
