wombatprotocol Posted March 18, 2019 Report Share Posted March 18, 2019 I have the display going to sleep with a timer and it works well. After a period of no activity, the timer is made and it goes to a blank HMI screen so when it wakes up you are not inadvertently pushing a button. My issue is that after touching the screen, I have a short timer (a pause) to another HMI display. It is taking 13 seconds for that HMI display to appear. For testing purposes, I put a Text box on the 0_Blank Screen display. I see that the display is flashing like it is repeatedly loading. I have tried Positive and Negative rising sequence on Timer TD1 and have the same issue. Here is the code: Any thoughts would be appreciated. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 18, 2019 MVP 2023 Report Share Posted March 18, 2019 ALWAYS use transition contacts to call HMI screens. Quote Link to comment Share on other sites More sharing options...
wombatprotocol Posted March 18, 2019 Author Report Share Posted March 18, 2019 Flex727....thank you! I have it all working now. I appreciate the advice. Quote Link to comment Share on other sites More sharing options...
