BTR Posted March 29, 2019 Report Share Posted March 29, 2019 Can anyone offer me some guidance? I purchased a 570, installed my ethernet card, established serial comms, tried to download the ethernet code, and realized I needed to upgrade the firmware. The following disaster occurred: Visilogic crashed while downloading the OS to a brand new V570 at 57.6K baud. This unit is a touch-screen without keyboards. The unit will not power up. There is no beeping, It is dead. I tried power cycle and holding screen for 5 seconds and tapping twice as suggested here. It is dead. How can I revive this unit and get on with my project. Any advice is welcome. Ben Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 29, 2019 MVP 2023 Report Share Posted March 29, 2019 Hi BTR, It sounds like you have consulted info and appear to be doing the right things. Other chances..... Tried different areas of the screen for the hold touch for bootstrap? Touch a bit longer? Have you been doing the reboots with nothing connected at all? ie physically remove all comms connections and wait 20s. Tried pulling battery for a few minutes? And incidentally, what Visi version were you using, and on what Windoze? cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 29, 2019 MVP 2023 Report Share Posted March 29, 2019 Also, and I know this sounds insulting....check that it isn't a completely coincidental slight unplugging of the power socket, they need a firm push to go in properly. Maybe it wasn't in properly to start with. cheers, Aus Quote Link to comment Share on other sites More sharing options...
DanT Posted March 29, 2019 Report Share Posted March 29, 2019 Hi; Have you tried : Connection -- Communication-PC Settings 6th Tab - System Mode -- Get ? if it responds, then switch to Factory Boot and then try the OS Download again Also - V570's like to communicate at 115,200 Baud Dan Quote Link to comment Share on other sites More sharing options...
BTR Posted March 29, 2019 Author Report Share Posted March 29, 2019 Issue is resolved. As Dan T suggested, 1. Power off. 2. Touch screen until power cycled On for over 1 second. 3. Tap screen several times. 4. Go to Connection in Visilogics. 5. Go to Communication -PC settings and select 115200k baud (i had used 57.6k, which may have caused the problem). select Get to confirm the unit is communicating. 6. Proceed with os download as before. Just for clarify: 1. Power was never an issue. The plug was firmly attached, and I noticed the draw on my v130 dimming every time I plugged in the v570. 2. My confusion was in expecting some visual response after the power cycle and tapping routine. When the unit stayed black screened, I panicked. I should have tried to connect to it. 3. Thanks to Tom from tech support for stepping me thru. all good now. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 29, 2019 MVP 2023 Report Share Posted March 29, 2019 Thank you for replying back with the resolution to your problem. Glad you're back up and running. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 29, 2019 MVP 2023 Report Share Posted March 29, 2019 Good. And good info Dan, I was thinking along the lines that absolutely nothing was happening. I'd like to pin this with a slightly changed name if no-one objects, as I always remember previous topics that have this sort of thing mentioned during discussion, but can never find them easily. It is the sort of thing that needs to be prominent for users in "distress". cheers, Aus Quote Link to comment Share on other sites More sharing options...
BTR Posted March 31, 2019 Author Report Share Posted March 31, 2019 I have no objection to changing the name. I was pretty impressed with how the system recovered, and how you all swung in to action to get me going again. My main objective is to make sure others have an easier time getting going. Thanks again. Quote Link to comment Share on other sites More sharing options...
thaonhipili123 Posted July 11, 2019 Report Share Posted July 11, 2019 I find this system quite convincing because changing the name is not so important that it is impossible to change it Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 11, 2019 Report Share Posted July 11, 2019 3 hours ago, thaonhipili123 said: I find this system quite convincing because changing the name is not so important that it is impossible to change it thaonhipili123, What do you mean by saying this? Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 2, 2020 Report Share Posted June 2, 2020 Btw, it is nearly impossible to hard-brick a V570 or any of the enhanced PLCs. The PLC has a piece of un-programmable software/code which handles the initial load of the PLC. Even if you erase the entire FLASH / MMC of the PLC, this software will still remain, and it will allow you to burn the FPGA, Boot as OS. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted October 14, 2020 Report Share Posted October 14, 2020 On 3/29/2019 at 1:53 PM, DanT said: Hi; Have you tried : Connection -- Communication-PC Settings 6th Tab - System Mode -- Get ? if it responds, then switch to Factory Boot and then try the OS Download again Also - V570's like to communicate at 115,200 Baud Dan Greeatings I have vision V280 and I have problem. I do upload program and povver supply in this moment going off , in the middle , vvhen i povver on my vision i havnt anythin on screen , have you some solution ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted October 14, 2020 MVP 2023 Report Share Posted October 14, 2020 4 minutes ago, t0r3r0s said: I do upload program and povver supply in this moment going off , in the middle , vvhen i povver on my vision i havnt anythin on screen , have you some solution ? Did you try the suggestions in this post? Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted October 15, 2020 Report Share Posted October 15, 2020 I try it but same problem , on v280 i havnt touch screen ,i try get on tab 6 , and i get same info look photo https://ibb.co/YZgnstG Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 15, 2020 MVP 2023 Report Share Posted October 15, 2020 Is the screen totally blank? For starters, look in the Help under topic "bootstrap" on how to get the PLC into a mode where it will be more cooperative. A V280 is a standard PLC, as opposed to a V570 which is an enhanced unit. The suggestions here don't necessarily apply. The default baud rate for a V280 is 57600. Visilogic does not automatically try this baud rate, but relies on what the user sets it to. Joe T. Quote Link to comment Share on other sites More sharing options...
