Pedrooo Posted March 30, 2019 Report Share Posted March 30, 2019 Hi Since the SD Card is difficult to remove, I would like to read the content via a serial port, RS232, USB, Ethernet. Which port is the easiest to implement and how to do it? Thanks in advance Pedrooo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 30, 2019 MVP 2023 Report Share Posted March 30, 2019 Using the Unitronics SD Card Explorer application, you can read the SD card in any manner that you use to connect to the PLC. with VisiLogic. The communications setup is exactly the same. Quote Link to comment Share on other sites More sharing options...
