Hi. I need help.
How i change the screen start in display HMI?
For exemple: The PLC start with the display 3, but i need than start with the display 1.
You understand the situation?
@Heitor, I moved this to a new topic since it did not belong in  the thread you replied to.
The answer to your question is that you can't change which screen is the Start-Up screen. You can create a new HMI screen and copy the elements from your Start-up screen to it. Then you can edit the actual Start-Up Display to be what you want. It is recommended that you do NOT change the name of the Start-Up Display, as that does not change the Start-Up property. But if you do, you  can always tell which is the actual Start-Up Display by looking for the orange highlight.
