Sign in to follow this
Meetto
UniStream doesn't identified via USB
Dear Sir.
I connected my New HMI panel USP-156-B10 through USB with my PC. After connecting it showing "identifying new hard ware, but not getting connected.
checked in control panel the driver is showing in Network adapter. I cannot connect through either net cable as well. I am using windows 7 64 bit.
Can you please help
screen shot.docx
I believe USB is converted to Ethernet inside the Unistream. Your firewall could be blocking it. I use Avast and have to put it in "silent mode" or add an exception for USB to Unistream to work.
  • Upvote 1
