Chjesus Posted April 16, 2019 Report Share Posted April 16, 2019 Hi guys, i have one problem in my plc Jazz JZ20-R31, problems the connected. I use 1- U90 Ladder V6.6.45 2- Cable MJ20-22-C525 3- Cable Adapter db9 (Serial) to usb 4- have Windows 7 Ultimate x64 bit The mistake he gives me is Communications could not be established due to one of the following: - Cable Connections are not secure - TimeOut is too short - Incorret communication settings. Check your cables and communication settings and try again. Previously it worked for me but I had some problems and I was forced to change my hard drive, without being able to obtain the information. I apologize in advance for my English, it's not very good. Thank you! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 16, 2019 MVP 2023 Report Share Posted April 16, 2019 Make sure you have selected the proper COM port in the U90 Ladder, as it can sometimes change. Go to Device Manager to confirm. Quote Link to comment Share on other sites More sharing options...
Chjesus Posted April 16, 2019 Author Report Share Posted April 16, 2019 1 minute ago, Flex727 said: Asegúrese de haber seleccionado el puerto COM adecuado en la escalera U90, ya que a veces puede cambiar. Ir a Device Mana ger para confirmar. I'm using COM 3 on both my laptop and U90 Ladder Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 16, 2019 MVP 2023 Report Share Posted April 16, 2019 Did you confirm in Device Manager that COM 3 is the correct com port? If you had to change hard drives, you may have a different driver for your USB to Serial adapter. Try re-installing that driver. Quote Link to comment Share on other sites More sharing options...
Chjesus Posted April 17, 2019 Author Report Share Posted April 17, 2019 6 hours ago, Flex727 said: Did you confirm in Device Manager that COM 3 is the correct com port? If you had to change hard drives, you may have a different driver for your USB to Serial adapter. Try re-installing that driver. I attach an image. I use the same COM3 port and the same cable for another plc using the visiLogic program and it works perfectly. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 17, 2019 MVP 2023 Report Share Posted April 17, 2019 The JZ20 series has a built-in USB port that uses the SiLabs CP210x driver. Did you try plugging a USB mini cable into that port? It will show up as a different COM port on your device manager. Joe T. Quote Link to comment Share on other sites More sharing options...
Chjesus Posted April 17, 2019 Author Report Share Posted April 17, 2019 19 minutes ago, Joe Tauser said: The JZ20 series has a built-in USB port that uses the SiLabs CP210x driver. Did you try plugging a USB mini cable into that port? It will show up as a different COM port on your device manager. Joe T. OMG it worked!!! Thank you. I was all day trying to solve this problem. Sorry I have another PLC Jazz but JZ10. It does not have that port, it should make a new topic or I can use this topic since the error is the same. Quote Link to comment Share on other sites More sharing options...
DanT Posted April 17, 2019 Report Share Posted April 17, 2019 The JZ10 Needs the JZ-PRG Programming Kit to communicate and program. Contact you local distributor if you do not have the kit. There is a Dongle for the Port in the JAZZ and a RS232 DB9 connector- MJ20-22-CS10 - and a 6 wire cable in the kit. DanT Quote Link to comment Share on other sites More sharing options...
Chjesus Posted April 17, 2019 Author Report Share Posted April 17, 2019 7 hours ago, DanT said: The JZ10 Needs the JZ-PRG Programming Kit to communicate and program. Contact you local distributor if you do not have the kit. There is a Dongle for the Port in the JAZZ and a RS232 DB9 connector- MJ20-22-CS10 - and a 6 wire cable in the kit. DanT before the hard drive was damaged, I used an MJ20-22-CS25 cable and its usb converter together with the u90 ladder version 6.4.0 on my previous hard drive and it worked correctly. Quote Link to comment Share on other sites More sharing options...
