Sign in to follow this
t0r3r0s
Problem with store to MI register
Greeatings.
 have a problem with encoder counting, I use the v700 and the expansion module D16A3 / RO16.
I36 is input  with a fast counter and use it to measure the length.
But I have a problem when I need to reset the value so I record 0 in the MI register, in the picture part of the code.
Did he have a similar problem or did somebody know the same thing?
As long as I remember, the use of HSC with expansion modules, involves  a hardware reset (I37 for reset). Alternatively you can use another register as a buffer.
Suggestion: use "greater than", instead of "greater" when you compare values.
I believe HSC cannot be reset on expansion unit from software, you need to use hardware reset (a physical input on D16A3-RO16 module). Take a look at this topic:
i try with greather than same problem ,  i can chose hsc and hsc with reset  and I chose with only hsc .
