Sign in to follow this
Rog
Azure SQL help
Trying to connect to a Azure sql server running the latest version of SQL server. I can connect using telnet and SSMS no problems. The unistream can connect to a local host using sql express. However when i connect using the same info. I get error which is the pic attached. I am kinda at a impasse. So what server on the unistream line compatible with?
  • Like 1
