Hello,
Can somebody help me. I have two PLC's, a Vision V700 and a FATEK, both with TCP / IP communication. I have to communicate the Fatek (slave) with the V700 (Master). Please, if someone has information, I thank you.
It looks like the FATEK supports MODBUS/TCP. Just set up your FATEK with the MODBUS TCP parameters as a slave and assign IP addressing, port number, etc. Match that on the V700 side as Master and it should work easily. There are example projects that came with your VisiLogic installation that will show you what to do in the V700 for MODBUS TCP Master.
