Swervomotor Posted May 1, 2019 Report Share Posted May 1, 2019 What are some ways to speed up screen changes in your project? I have a screen with 9 data tables (1 visible at a time based on the value from a combo box) and about 30 buttons (same only 3 visible based on combo box value) It takes about 5 seconds to load this screen. What are some ways to speed up screen changes and optimize HMI design? Quote Link to comment Share on other sites More sharing options...
Ofir Posted June 5, 2019 Report Share Posted June 5, 2019 Hi, Loading a screen with many data tables which in general contain a lot of information takes more time... If you will have 9 displays - one for each data table - is it loading fast? Can you work with this solution? Quote Link to comment Share on other sites More sharing options...
