jvalstar Posted May 2, 2019 Report Share Posted May 2, 2019 I'm having a problem during downloading my program to a Unistream USP-104-B10. I get the following error: Tags Allocation The size of the Tags memory in this project has exceeded the PLC memory capacity. The error list shows: Tags - Global tags - The tag memory should be reallocated. Please run Ribbon > PLC > Reallocate Memory. How do I fix this problem? Or how can I see how many tags i have too much? Thank you! Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 5, 2019 Report Share Posted May 5, 2019 Most likely that you have you have exceeded the retained memory total size (256KB). Most of the times it happens due to large Data Tables. Quote Link to comment Share on other sites More sharing options...
NutzlosNorm Posted November 23, 2020 Report Share Posted November 23, 2020 Any way to increase the amount of memory (SD card)? How can I see how close I am other than hacking away at my program until the error goes away? I have this error in a program for a USC-B10-B1 and I have three data tables. Quote Link to comment Share on other sites More sharing options...
