sebastien Posted May 2, 2019 Report Share Posted May 2, 2019 I am trying to display french language on my V130 but when I write accent like <é> is display on the screen <**> Probably the font is not install in my V130 Any idea to solve this issue Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted May 3, 2019 Report Share Posted May 3, 2019 Go to "HMI - Font Handler" menu, select the font you want to modify and select those characters you want to show (only not default fonts) Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted May 3, 2019 MVP 2023 Report Share Posted May 3, 2019 Choose a font that contains all the characters you may want - in this case Arial 14 Bold- If the character is highlighted in blue you get to use it. I your case, the "è" character must be accessed using the Alt code Alt-0232. You can determine the code by hovering your mouse on the Font Handler window over the character you want and it will display a tool-tip box with the code. In your text object, hold Alt whilst entering the number from your numeric keypad and then release Alt. Note the the numbers at the top of the keyboard won't work - you must have Num-Lock on and use the keypad. If you're using a laptop, use the blue numbers on the keyboard. I had to hold Alt-Fn-blue numbers 0 2 3 2 then release Alt to do this. Voilà! Joe T. Quote Link to comment Share on other sites More sharing options...
