GenXMeds Posted May 6, 2019 Report Share Posted May 6, 2019 So I have wrote a program that we use on our conveyor for sorting tubing. We get a good/bad signal from a gauge, then use this to tell the conveyor when to blow a part into the conveyor. So the program works well for what we need, but I have found an issue when we started using it. I want to fill batch 1, then start to fill batch 2. When I am filling batch 2 I pull the parts and reset the part count on batch 1 to 0, well when I do this is starts counting again in batch 1. looking at my program this is exactly how I wrote it. I went to solve this issue today, and I cant seem to come up with how to get it to fill batch 1 until its full, switch to batch 2 and not stop filling on batch 2 until it's full. Then when its full it goes back to see if batch 1 if full still, if not then it will start filling that again. its coming clearer now that I try to explain it here. Thanks Tyler 1 blow 2 batch.vlp Quote Link to comment Share on other sites More sharing options...
