REGEX Posted May 6, 2019 Report Share Posted May 6, 2019 Hello, I have fresh instal WINDOWS 10 PRO 64bit 1809 build 17763.475. When I use version swapper and than start swap version of visilogic (for example 9.5.0) i saw 2 error (in pictures) and than app close. Any idea? (unilogic and visilogic function normally, only SWAP version crashing.....) and Yes: 1) UAC is disabled 2) instaled visilogic as administrator 3) run version swapper as administrator 4) run swap version visilogic 9.5.0 as administrator at WIN 7 32 were all OK... 😞 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 6, 2019 MVP 2023 Report Share Posted May 6, 2019 Be sure you are running Version Swapper from the latest version of VisiLogic you have installed. Do not use the Version Swapper from the older versions of VisiLogic. Quote Link to comment Share on other sites More sharing options...
Cam Posted May 6, 2019 Report Share Posted May 6, 2019 Also try to install your Visilogic's in order 9.4,9.5,9.8.65 etc... I had issues once when I installed 9.4 after installing 9.8.65 and 9.8.79. I had to uninstalled everything and re-install starting with the oldest version. Quote Link to comment Share on other sites More sharing options...
REGEX Posted May 6, 2019 Author Report Share Posted May 6, 2019 Yes, Version Swapper was installed with latest version of Visilogic. Quote Link to comment Share on other sites More sharing options...
REGEX Posted May 6, 2019 Author Report Share Posted May 6, 2019 3 hours ago, Cam said: Also try to install your Visilogic's in order 9.4,9.5,9.8.65 etc... I had issues once when I installed 9.4 after installing 9.8.65 and 9.8.79. I had to uninstalled everything and re-install starting with the oldest version. What do you mean? I installed only latest Visilogic 9.8.65 and other version i downloaded ZIP SWAP files from unitronics web, exctract to Unitronics directory and start/registers via Version Swapper. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 7, 2019 MVP 2023 Report Share Posted May 7, 2019 Also, read this post and my answer underneath it, and all the other referenced posts/topics I mention in my answer. My "virgin" installs method works well. It takes a little while to do, but is worth it in the end. Post: cheers, Aus Quote Link to comment Share on other sites More sharing options...
REGEX Posted May 9, 2019 Author Report Share Posted May 9, 2019 Thank you all. I don't know what I did, but suddenly it all worked. My last activity was that I deleted the old swap files and copied them again from the swap ZIP archive. Quote Link to comment Share on other sites More sharing options...
