meuhporg Posted May 9, 2019 Report Share Posted May 9, 2019 Hello, first of all I want to apologize in advance if it is not post in the right place or if my English is not good, I try to do my best. good now I explain my problem, as part of a school project, I have to adapt two PLC to control mini industrial facilities. that's good every automaton controls his installation only now I have to communicate two automata between them to be able to control stations from different automata so for that I use the block (RIR # 4) and it works perfectly for my first 4 values (here as can be seen on the programs reconstituted, since the master, we read the 4 word from the word 46 and we stocks from the word 200. the problem comes after, when I have to transfer a simple status bit (0 or 1 so). I use the bit to num function to put it in the form of a word, I try to read that word, and I use num to bit to recover the bit that interests me, but it does not work so I did a test, and it turns out that the bit is well transformed into a word, but that the RIR block # 4 does not read this word, while yet it seems to configure well. in summary, I try to transform my MB40 bit in the word MI100, and it seems to work, it's when I try to read my MI100 word to put it in MI240 that it seems to be wrong because when I try to display MI240 it remains at 0. I leave you as an attachment a reconstruction of the part that seems cloche of my program (the master and the slave, my teacher not wanting me to diffuse the programs of a school project) I really hope you can help me, thank you very much (PS: my PLCs are V350-35-TRA22 and a V350-35-TR20) master 1.vlp slave 1.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 9, 2019 MVP 2023 Report Share Posted May 9, 2019 First of all, you need to Read Holding Registers (R.H.R #3), not Read Input Registers (R.I.R #4). Also, you can read and write bits (coils) directly using Read Coils #1 and Force Coils #5 or #15. But the simplest method when you are communicating between two Unitronics Vision PLCs is to use the FB Read/Write Mixed Data. This FB allows you to enter a mix of operands and read or write them directly using a single function call. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 9, 2019 MVP 2023 Report Share Posted May 9, 2019 Also, do NOT use SB 3 for your communications. If one second intervals are sufficient for your communications, use SB 13. SB 3 will cause the PLC to attempt comms on every PLC scan for fully half of each second. You want to trigger communications with a transition contact or SB 13, which is automatically a transition contact. And place an inverted contact of MB 100 in front of the comms FB. Quote Link to comment Share on other sites More sharing options...
