Sign in to follow this
ddm
scada reads bits values inputs or outputs as an array
hello everybody,
working with WINCC scada and connected to Uniopc server I would like to know if it is possible to request more than one bit info at a time,
or more generally request array of values .
something looking like "plcName.MB0[10] to collect the first 10 memory bits for example.
trying this in many ways did not result well .
thanks
I'd pack the bits into an MI or ML in the PLC first.  What model of PLC are you using?
Does WinCC have a method to convert an integer to a bit array inside itself?
yes.
first thanks for your response.
but not always it is possible to add code to the plc.
