Ken Hoang Posted June 6, 2019 Report Share Posted June 6, 2019 Hello all, This is my first time working with Unitronics product and so far so good. I'm currently using the Samba SM35-J-RA22 to develop a control system for our product. On the home screen, we display the machine status and some operational parameters. Due to the small screen size, I'm looking for a function like the "List of Texts: by pointer" but with numerical values linked to MI instead of fixed text. At the bottom of the image below, as the user press the up/down button, the parameters should cycle through a list. I can make the parameter name cycling through using the "list of Texts: by pointer" but I couldn't find a way to do the same with the associated numerical values. I guess one way around this would be to have multiple display screen and when the user press the up/down button, the display jump to another screen with the appropriate parameter. However, this means that it'd require 5 displays for 5 parameters as an example. Another issue is the image quality. Even when I use high quality icon, when imported into Visilogic (and on the unit display), the image become quite broken. Is there a way to improve this? Any help is much appreciated. Ken. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 6, 2019 Report Share Posted June 6, 2019 Hi Ken, List of Text use MI as a string index. You can store respective values in sequential MIs and use indirect store MI to copy corresponding to string index MI to other MI, which you can show on display. Hope this is what you requested. About image quality: Display resolution is 320x240 dots. *PLC is not smartphone. Image allocate part of display. So it's size is smallest. You do not need to use highest resolution images. It is useless. B.R. Quote Link to comment Share on other sites More sharing options...
Ken Hoang Posted June 7, 2019 Author Report Share Posted June 7, 2019 On 6/6/2019 at 9:36 AM, AlexUT said: Hi Ken, List of Text use MI as a string index. You can store respective values in sequential MIs and use indirect store MI to copy corresponding to string index MI to other MI, which you can show on display. Hope this is what you requested. About image quality: Display resolution is 320x240 dots. *PLC is not smartphone. Image allocate part of display. So it's size is smallest. You do not need to use highest resolution images. It is useless. B.R. Many thanks for the suggestion Alex. I'll try that. Quote Link to comment Share on other sites More sharing options...
