chand345 Posted June 6, 2019 Report Share Posted June 6, 2019 Hi, What a solid red status LED means on a UIS-08TC? its reading -32768 which means connection fault and it reads that even when there is no thermocouple connected. Thanks. Help is much appreciated. Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted July 8, 2019 Report Share Posted July 8, 2019 I ran into a solid red LED with a transistor module, contacted support and they said all 0v and +V connections needed to be connected even if you were not using that row. Connected jumpers from 0V to 0V and +V to +V and it fixed the issue. Just a starting point but I would contact support. Quote Link to comment Share on other sites More sharing options...
