chand345 Posted June 14, 2019 Report Share Posted June 14, 2019 Can someone show me an example of code that causes the plc to go into sleep after 30 seconds and Kinda go into a idle screen. Only stuff I see examples on is in visilogic but can someone help me out and do it in unilogic? I'm sure it is simple but I am very new to this. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 14, 2019 MVP 2023 Report Share Posted June 14, 2019 You would run a timer activated by an inverted contact of the General.Touched bit. Use the Out bit of the timer to trigger an Action to change screen brightness. Quote Link to comment Share on other sites More sharing options...
Cam Posted June 16, 2019 Report Share Posted June 16, 2019 You may want to make an action to jump to another screen and then when the screen is touched jump back to the last display. This way no buttons you have on the screen are activated when filming out of sleep mode. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 16, 2019 MVP 2023 Report Share Posted June 16, 2019 5 minutes ago, Cam said: You may want to make an action to jump to another screen and then when the screen is touched jump back to the last display. This way no buttons you have on the screen are activated when filming out of sleep mode. This is good advice. Quote Link to comment Share on other sites More sharing options...
chand345 Posted June 17, 2019 Author Report Share Posted June 17, 2019 Thanks everyone, I've got it to work using your advice. I didn't know about the General options. Quote Link to comment Share on other sites More sharing options...
