Sign in to follow this
Ausman
6 pin RJ45 screwed terminal
Maybe this type of connector is useful in commisioning, but i do not use this type of connector in installation.
There is a risk of damage to the PLC connector by  applying some forсe to the adapter or cable.
Especially in the presence of vibration.
I usually use something like a classic adapter (MJ10-22-CS25 or the same).
Which is fixed not far from the controller and connected to OPLC with a flexible, standard short cable.
Ahh yes....but not if you are using 485!  Depending on local conditions dictates whether one of these goes in the final install, or I make up my own custom 6pin plug.   For ease of trials, though, this type is great.
cheers, Aus
