Addelichtman Posted June 19, 2019 Report Share Posted June 19, 2019 Hello, how can I change the IP address of an Ethernet IP node dynamically (via edit box on a screen)? Your help is very much appreciated. Ad Quote Link to comment Share on other sites More sharing options...
Cam Posted June 20, 2019 Report Share Posted June 20, 2019 I don’t believe there is a way to do this as you can not assign a variable to the node IP. why do you need to dynamically assign the IP anyhow? Quote Link to comment Share on other sites More sharing options...
Addelichtman Posted June 20, 2019 Author Report Share Posted June 20, 2019 Hello Cam, thanks for your answer. To me it is obvious because we ship the PLC to any customer and we do not know up front what there communication parameters are. Please Advise, thanks Ad Quote Link to comment Share on other sites More sharing options...
sgull Posted June 20, 2019 Report Share Posted June 20, 2019 Under the Numeric elements on the right you have "IP address edit" and "IP Settings Edit" Can you place these on the screen for the user to access? Can you also change these from the info mode? Quote Link to comment Share on other sites More sharing options...
Cam Posted June 20, 2019 Report Share Posted June 20, 2019 That works for the PLC itself but not a node which is declared under the scanner Quote Link to comment Share on other sites More sharing options...
