JL_SMB Posted June 20, 2019 Report Share Posted June 20, 2019 I would like that Info mode accesss in Unistream was designed in another way. The Visilogic way was good enough, at least I was able to place any buttons wherever I wanted. With Unistream method you have a considerable dead zone where you can't place any button because it simply won't work, because it is reserved to access the System configuration. Wouldn't it be possible to choose the corner where the info mode has to be accessed? The upper left corner is where I always put the Home or Back button, but in any case I think that space should be available to place any button, not just reserved for the info mode access. I find it an annoying limitation. Quote Link to comment Share on other sites More sharing options...
ROKY_93 Posted March 24, 2020 Report Share Posted March 24, 2020 Hello, i also had the same problem with the button not working in the right top corner. But there is a solution, not to fix this but you can make your button work. Unilogic has a category of System bits and under the caption General there are information about Coordinate x,y where you press the touch screen and a bit when you press it. The touch bit and coordinates are working on whole screen. You can use this info to write ledder logic. When you press the touch screen, a touch bit turns on, then check the condition if the x,y coordinates of your press are within area where your button is placed on hmi. If condition is positive then make an action maybe jump to another screen. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 24, 2020 Report Share Posted March 24, 2020 Dear Forum members, Thank you for suggestions. Please send your requirements to support@unitronics.com We will review and reply. Best regards. Quote Link to comment Share on other sites More sharing options...
