Sign in to follow this
Deybid Castillo
communication plc unitronics v130 and HMI DELTA
Hello, my name is deybid, I am looking for a little help with this plc unitronics and this hmi delta brand, since it is the first time that I am going to work with these equipments and I would like to have a modbus communication, since it is the only option that It gives the hmi delta software but I can not get the communication through the plc cable rj11 -> rs232.
I have been investigating the program that I have to load in the PLC since I want to work as a slave, but even so I do not have much knowledge about this equipment. I would appreciate it if you would help me. Thank you and I'm sorry for him. English.
65192539_2280523652002197_204327365390630912_n.png?_nc_cat=110&_nc_oc=AQnwE7yqZyx0VPF7kJW_cP-vDBaE4ti2XrO9IprFu6WBopuaB82kS1sz-oZ0eJ1CmNI&_nc_ht=scontent.flim15-1.fna&oh=d66014e693f227a1e706a92034eb4356&oe=5D7E92AE
Resultado de imagen para rj11 a rs232 unitronics
That cable you have pictured does not work for modbus 485.   You need to have a cable that connects to terminals 1 & 6 on the com port, and also have some physical jumpers set properly.  This is fully explained in the manuals for a V130.  And initially drop your speed to 9600 until you get it working, then adjust if the system can tolerate it.
cheers, Aus
