2rlp Posted May 19, 2011 Report Share Posted May 19, 2011 Hi, I am trying a Shift Logic in a V130. I need to TEST bits to enable certain Outputs. The PLC does not behave as per the details in the HELP section. In the help you have shown that in order to check bit 21 of ML2, B will need to be 21. However, in reality, B has to be 10. ??? Is the Help wrong or am I wrong? Ron Quote Link to comment Share on other sites More sharing options...
