kikitron Posted June 25, 2019 Report Share Posted June 25, 2019 Hi to all, I have one project that I read analog pressure sensor 4-20mA (0-250BAR). I need to switch valve ON and OFF on setted value min and max. Now I have setted that valve is on allways when he is below 160bar and when he reach 160bar he goes off. And when pressure drops below 150bar he is ON again till 160bar. Program is working but if I would like to change minimum and maximum values I need to set it in the program and writte it to plc. Is it possible to do changes directly on the display for MIN=0-250bar and for MAX=0-250bar? For example I would like to change MAX=180bar and MIN=100bar directly on display. test.U90 Quote Link to comment Share on other sites More sharing options...
kikitron Posted June 25, 2019 Author Report Share Posted June 25, 2019 1 hour ago, kikitron said: Hi to all, I have one project that I read analog pressure sensor 4-20mA (0-250BAR). I need to switch valve ON and OFF on setted value min and max. Now I have setted that valve is on allways when he is below 160bar and when he reach 160bar he goes off. And when pressure drops below 150bar he is ON again till 160bar. Program is working but if I would like to change minimum and maximum values I need to set it in the program and writte it to plc. Is it possible to do changes directly on the display for MIN=0-250bar and for MAX=0-250bar? For example I would like to change MAX=180bar and MIN=100bar directly on display. test.U90 77.25 kB · 0 downloads I found the sollution Thank you anyway, admin can delete this because I was to quick to open new topic. Regards Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 25, 2019 MVP 2023 Report Share Posted June 25, 2019 Thanks Kikitron for letting us know. It is often amazing how the simple act of telling someone else about a problem switches a lightbulb in your head and lets you solve the problem yourself! I have always thought it is because in explaining the issue, a fundamental concept previously missed becomes apparent. cheers, Aus Quote Link to comment Share on other sites More sharing options...
