bluesparky0791 0 Report post Posted June 25 Hello, I am trying to print a label from my Samba to a Zebra GK420d epl. I am definitely struggling, I am not familiar with Visilogic or zebra printers. right now I am just trying to get it to print through the serial port but eventually I would like to print through Ethernet using the Zebranet 10/100 external print server, but one thing at a time. Attached are some screenshots with the init and the Zebra configuration. Any and all help will be greatly appreciated! Quote Share this post Link to post Share on other sites
bluesparky0791 0 Report post Posted June 26 Hello? Is there anyone out there? Quote Share this post Link to post Share on other sites
Ausman 138 Report post Posted June 27 There is/are. Nearly everyone here is not a Unitronic's employee...we are all volunteers with jobs. Someone will help you when they can, which is generally fairly fast. If you can post your entire program that would be of help. cheers, Aus 1 Quote Share this post Link to post Share on other sites
bluesparky0791 0 Report post Posted June 27 Here is the program with the printer logic started and also a zebra printing example programming I found. Fib Count With Example.vlp Quote Share this post Link to post Share on other sites
kratmel 12 Report post Posted June 28 At the 1st you must read this two document https://www.zebra.com/content/dam/zebra/manuals/printers/common/programming/zpl-zbi2-pm-en.pdf https://www.servopack.de/support/zebra/EPL2_Manual.pdf After that you must setup correct serial connection (see printer manual), run example on PLC and try to print some words. In you printer configuration control char 5Eh is used (see it in example Protocol block). But you Protocol configuration in file do not use any control character. Quote Share this post Link to post Share on other sites
