HELLO FRIENDS
I NEED YOUR HELP. I HAVE INSTALLED IN ANOTHER MACHINE 06 EXPANSION MODULES, AFTER THE TRANSFORMER THAT FEEDS THEM IS DROWN, THE "RUN" SIGNAL IS INTERMITTENT. SOMEBODY KNOWS WHAT SHOULD I DO?
Are the modules from another machine or brand new?  Did you place them in exactly the same physical sequence as before?  Is the controller set to run these modules?
Does "transformer that feeds them is drown" mean that the system got wet/flooded?   Or is "drown" a translation mixup and meant to be "down"?
You can post in your own language Ramon, many people here on the forum can/will translate.
cheers, Aus
