JL_SMB Posted July 11, 2019 Report Share Posted July 11, 2019 Not much to add to the title. When using a timer.out bit to trigger a digital alarm, UniStream is not detecting it. I had to set a bit with the positive transition of the timer, and then reset it after the alarm state has been activated. Quote Link to comment Share on other sites More sharing options...
NoamM Posted July 15, 2019 Report Share Posted July 15, 2019 Hi JL_SMB, Open a ticket on Unitronics "Help center" at https://support.unitronics.com/index.php the Support team will assist. Quote Link to comment Share on other sites More sharing options...
