MortenS Posted May 23, 2011 Report Share Posted May 23, 2011 Hey Im setting up a lot of vision 350 and 570. I've been using a combination of SD-kard and RS232. Is there a way to setup a blank PLC via IP. Is this possible. Does anybody know the IP I have to use and what name? using unidownloader. Thanks MortenS Quote Link to comment Share on other sites More sharing options...
Emil Posted May 23, 2011 Report Share Posted May 23, 2011 Hey Morten, You can set initial Ethernet parameters from Info mode and this way you can contact from, let's say VisiLogic and operate (download to, for example) totaly new controller. Quote Link to comment Share on other sites More sharing options...
MortenS Posted May 24, 2011 Author Report Share Posted May 24, 2011 Have to try this Thanks Quote Link to comment Share on other sites More sharing options...
Bill Smith Posted May 24, 2011 Report Share Posted May 24, 2011 See this post: this has the steps I needed to make this download to a brand-new work. Quote Link to comment Share on other sites More sharing options...
