Rifet
Visilogic 1210 with wincc flexible 2008
Hi guys. I need help.
Does any of you has experience of connecting wincc flexible 2008 to unitronix plc (visilogic 1210). This is my first time trying and I don't know where to start from. In wincc flexible I have option of "OPC" and "Modicon MODBUS TCP/IP"  communication.  What is procedure for reading tags from visilogic using wincc flexible?
What is easier to use? Maybe OPC? Do I need to use UniOPC to read tags from visilogic plc and than connect that to wincc flexible?
Btw I have no experience with OPC and this would be my first time.
Thank you all :)
Modbus TCP/IP will probably be easier.  Do you have a link on how to configure this driver in WinCC?
Look at the Unitronics Help on Slave Addressing Tables to see how Modbus addresses translate to MIs and MBs.
