I tried to find this way to declare connection address on smtp server. For example: I create an account on SMTP2GO. THEY RECOMMEND THIS STATEMENT mail.smtp2go.com, but not possible. I CAN PUT NUMBERS and not address of this type. I am crazy about this software ....
Hi interroga,
Everything have solution.
VisiLogic PLCs are working with IP addresses.
PCs are doing this conversion internally. UniStream PLCs too.
To convert  mail.smtp2go.com to IP address, you have to use DNS resolver.
See SM35_DNS_Resolver.vlp example in directory
C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Examples\Version 900\Project examples\Communications\Ethernet\
Use IP address, resolved by DNS resolver, for communication with email server.
*It seems that you added pictures to post, but we cannot see them.
Hi;
In My test program     The SMTP2GO   Parameters for email are :
                 Remote  IP     216.22.15.247
                Remote Port   2525
DanT
