Danny Edison Idarraga Posted August 3, 2019 Report Share Posted August 3, 2019 Buen día. Soy integrador de Automatización. Un cliente intento actualizar el OS de un OPLC V350 pero éste se bloqueo. Ahora cuando se energiza, solo se oye un sonido intermitente y luego deja de sonar, pero la pantalla no enciende. Como puedo desbloquear el OPLC para actualizar el OS. el Serial del OPLC es LM00F10V7 V350-35-R2. Gracias. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 3, 2019 MVP 2023 Report Share Posted August 3, 2019 Translated- Good day. I am an Automation integrator. A client tried to update the OS of an OPLC V350 but it crashed. Now when it is energized, only a flashing sound is heard and then stops sounding, but the screen does not turn on. How can I unlock the OPLC to update the OS. The Serial of the OPLC is LM00F10V7 V350-35-R2. Thank you. It probably had to do with how he connected to the PLC when he tried to update the OS. Look at this post- Joe T. Quote Link to comment Share on other sites More sharing options...
Alejo Posted June 22, 2020 Report Share Posted June 22, 2020 El 3/8/2019 a las 15:17, Joe Tauser dijo: Traducido Probablemente tuvo que ver con cómo se conectó al PLC cuando pude actualizar el sistema operativo. Mira esta publicación Joe T. tengo el mismo problema Joe ayudame Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 22, 2020 MVP 2023 Report Share Posted June 22, 2020 For starters, do you have the same model (V130-33-TR20)? How exactly are you connecting between your PC and the PLC? What exactly does it say on the screen? What operating system is on your PC and what version of Visilogic are you using? Joe T. Quote Link to comment Share on other sites More sharing options...
Angie alvarado Posted March 29, 2021 Report Share Posted March 29, 2021 Tengo el mismo problema, me conecto con un cable usb a serial, tengo w10 y la versión del visio es 9.8.91 Quote Link to comment Share on other sites More sharing options...
