Russ Is Not Happy Again Posted August 7, 2019 Report Share Posted August 7, 2019 So I can export a data table to excel no problem. Open that excel file full and it is full of the bad format triangles. Copy and paste the data I want from another excel file onto the one I just exported, and KABOOM, no import allowed. THIS ERROR (The data table file could not be created due to incompatible data types. This is because the value " was entered into "REAL" field.) I have tried every cell, number format excel has to offer that I can think of to fix this. WHAT GIVES. Some how there is some important information that is not included in the published manual. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 8, 2019 MVP 2023 Report Share Posted August 8, 2019 Post your program and the exported offending excel file. We need this to see what's going on. It will help make Russ happy. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 10, 2019 MVP 2023 Report Share Posted August 10, 2019 It would seem that Russ doesn't want to be helped along the road to happiness? Russ? Russ? cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 16, 2019 MVP 2023 Report Share Posted August 16, 2019 Happened to be on and saw that Russ was also online, but alas.....still no response. 🤨 cheers, Aus Quote Link to comment Share on other sites More sharing options...
Russ Is Not Happy Again Posted August 16, 2019 Author Report Share Posted August 16, 2019 Thank you all, but I did finally get my problem solved Quote Link to comment Share on other sites More sharing options...
